We just braket race. I do have a 150 shot on it for those times when I feel like it's not going to run the number. our engine is 11.2 to 1 with aluminum heads and only 34 degrees of timing. on alcohol. Maybe if I ever build my W7 engine I might consider a crank trigger and belt drive. This current engine is a stock block 421" with Rod Bloomer heads.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
