Originally Posted by moparx
Originally Posted by JohnRR
I use regular old Hi temp wheel bearing grease in a grease gun tube , use an injector tip to fill it after putting it on the axle. I use a bearing heater to install them so I do it after it cools.
as above. ^^^^^^^^^^^^^^^^^^^^^^^ iagree
beer
X 3 wink I do use a bearing packer on the bearings. I cover them with Saran wrap while pressing them on. I cover them again with saran wrap until they are being installed in the housing.
