Originally Posted by JohnRR
Originally Posted by A727Tflite
Originally Posted by Cab_Burge
Originally Posted by slantzilla
If you had it rebuilt twice and the noise hasn't changed, it's time to look elsewhere......
I would take it to another shop next, what ratio is it?
Why does it have an earlier pre1965 rear end in it? 1964 was the last year Mopar used tapered axles in the 8 3/4 rear ends, 1965 and later should have the later style flat flanged axles in it without the tapered axles scope work
He mentioned tapered axles bearings, not tapered shafts.
... and it's 3.23 gear .
No hum off the ground , if it's in the rear that would have me checking the axle bearings , is the endplay set right ?
My stepdad said he set the endplay, with very little movement. He as you said thinks it maybe the axle bearings
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher
Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
