Yes, there are some chains here that unless your tires look nearly new they will refuse to service them.
They won't let you buy anything less than 4 new tires otherwise your car could handle 'dangerously'.
If you buy 4 new tires they will tell you they can't warranty them unless you also get a front end alignment to go with it
Then we get to the employees that work there that use impact guns on everything and think they are NASCAR pit crew guys. Cross threaded lug nuts or broken wheel studs are your fault not theirs.
