Originally Posted by Hoop
Well, I all ready got a new HEAVY DUTY DOUBLE ROLLER TIMING SET off ebay because I was going to go with a stock cam, but then I was having a had time getting ahold of one, keep getting out of stock & refunded, so I order the edelbrock one from the auto parts, then I read this on jegs! "Do not use late model timing chain and gear sets that are designed for emission-controlled engines. They are machined in a retarded position and are not recommended for this camshaft installation. Use Performer-Link Timing Chain Gear Set 350-7803 or similar set."... This is the one I got off eBay, so I'm wondering should I use it or get the edelbrock one? https://www.ebay.com/itm/133134084872
You should degree every one. I trust none.
