A possible solution for an A/C condenser would be to use one fron an 05ish Ram 1500. They are quite compact and self contained with their own electric fan. They mounted at an angle between the rad and driver's headlight but could easily be remote mounted anywhere the fan can draw air to blow through it.
Kevin
