Wow, tight tight. I do plan to take off the belt driven fan and go with electric fans mounted near to the radiator core. My Dakota chassis has the radiator, AC condensor, and the trans cooler to plan for mounting onto the front of the Dakota frame but fit within the 56 radiator core support. I have read the 8HP-70 trans runs hot by nature, so a trans cooler may be good to keep under the 56. This will be an interesting project to say the least.
My 56 C3-B8 Dakota build
