Good looking 54 Gene. I knew if I threw out that bait you'd take the hook. Good info and thanks. Just playing aorund with ideas in my head.
As you know, my 56 cab is planned to go on my 2001 Dakota chassis, using the firewall/floorpan into the 56 cab. My plan is to move the 56 cab back an inch, maybe two, to get the front wheel centerline placed better in the fender openings. If I recall, on your recent build you modified the front fenders to move the alignment to the front wheel centerline?
My 56 C3-B8 Dakota build
