...while a very subjective question it is a valid one. In my case, 'nice power' will be whatever the original LA 318 had here at 7000 ft altitude: it had 360 heads, a "4bbl" cam with a nice mild lope, and I don't know if it had 318 or 340 manifolds...but it was just a nice warm 318 and sprinted happily to around ~5500 rpm - nothing fancy. I've no idea what the hp was but it was 'plenty'. I can only presume a similar magnum 318 with a similar cam will run just as well, and that will be plenty for me.
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
