Take it down to nothing but the shaft, put bottom part in vise, attach a slide hammer to the top nut and pull on it till it’s the right length. Only simple option. I would do this every time I wanted a standard box column, then I’d weld the end. A wreck with the force that would be needed to drive the column into your body, no worry you’ll be dead anyway from that impact.
