There isn't enough room for it to pull apart when everything is together. You might get a little bit of a rattle with the pins sheared but it isn't a safety issue since the shaft will still collapse in an accident. My Duster had the pins sheared and it worked fine. There wasn't anyway for the shaft to come apart so I just drove it.
