Many couplers use a small pin to prevent the assembly from separation. But, it's a small pin, probably there mainly to prevent separation while the column is out of the vehicle. I wouldn't trust it to prevent separation while driving.
If, your shaft is loose enough for it to bottom out in the coupler body, it's loose enough to not cause any problems.
