I ended up getting the Terminator X stealth 4150 throttle body.Just finished installing Terminator X today.
Started instantly it was 38 degrees and idled at 900 when warmed up and seems to run well. Install was straightforward used the Holley in-tank pump easy peasy. I decided not to buy the Hypersark instead I purchased a new ignition module from FBO that eliminates the ballast.
Glad I bought it last spring it has gone up quite a bit like everything. Hopefully, will take it out in a day of 2
