With all the yes it will no it won't one thing that has not been mentioned is pavement conditions. IE: wet, dry, dry but dusty, sand, salt etc.
the only stock 383 I owned that would break the tires loose on a roll was if made a right turn and nailed it in low entering the turn whistling
Straight line, dry clean pavement, NADA.
