Originally Posted by chargervert
[quote=ChryCoGuy]
If you do something wrong,no matter how much detail you put into it at the end of the day it's still wrong. The right way to do it was to use the Cuda roof,extend it using the center of a second cuda roof,cut the door window frames off the Coronet doors and have glass made to fit the roof properly. If anyone could have pulled this off correctly it was Dave,his company makes glass. He chose to do it the easy way instead of doing the pillarless model with the right roofline like the drawing. Then he got pissed off at everyone who called him out on the car for the roof looking effing goofy,well it does look effing goofy. The roof lines of the two cars aren't even close,and the curved A pillars that get wider as they go up look like crap against the Cuda straight windshield moldings that end six inches below the side glass height!
never saw it from that angle. my god that is bad. it really is the perfect example of just because ya can doesn't mean you should.
The rear window is even worse.
John
The dream is dead, long live the dream.......😥
