Hello.
I am having a 470 built for my car, and before it gets put on the dyno I was wondering what you guys think it will make. This is far from an all out build, just a fun street /strip engine designed for pump 93.
470" short block with Ross pistons, Eagle rods and Molnar crank. ( Molnar rods were not available when it was built)
10.5:1 Compression
Trick Flow 270 heads with Harland sharp rockers( 1.5 ratio)
Trick flow intake port matched to the 270 heads.
Holley 950 HP carb
Comp 23-233-4 Cam, solid flat tappet, 252/260 @ .050, .540/.588 lift, 110 LSA ( XS290S grind)
Any guesses?
Any idea what the venturi size is on that 950 HP?
