Originally Posted by markz528
Originally Posted by John_Kunkel
[quote=markz528] All components inside the transmission looked okay.
We did fully disassemble it. We found nothing that looked incorrect to us other than all the contamination.
So My fresh 727 and freshly tightened converter would go forward in all gears including 1, 2, 3 neutral and reverse.
The converter isn't causing it to move in all gear selections. There is an issue in the trans.
Doug
