Originally Posted by SNK-EYZ
If you were simply using the drivetrain because you already have it, it would be great for an old truck or a 50's era car (full frame) that has lots of floor pan/trans tunnel room.
Anything else, the trans is a poor choice.
It is not a matter of room, it is a matter of poor gear ratios, really wide spreads and clunky shifting. Not to mention is weights a ton.
