Quote: Why the no tube car rule for class I? The tube chassis cars started coming out in 1972. You are eliminating a bunch of ERA correct cars, for example, the Roy Hill (ex Butch Leal) Duster you have pictured would not be allowed to compete.
We have the John Hagen Pro Stock Duster, the car is being restored right now out west to be identical as it was run in the mid 70's Lenco and all, and I am putting together an ERA correct destroked 396 Pro Stock Hemi to the core, right down to those ungodly heavy steel rods.
Need to say that the McCandless Demon is as correct as I've seen a Mopar Pro Stock resto, job well done.
You can easily run in Class II. Only the sub compact cars used tube chassis early on. The Hill Duster is from 1975. Bring your car. Let's race!
