I'd build based on the factory torsion bar/assymetrical leaf spring setup. Getting that to handle exceptionally well is pretty easy. Yes, handling suspension will affect 1/4 mile performance, not enough to take the fun out of it. You can experiment with removing the front sway bar links at the strip.
