I'm going to try and fab up a set of my own fenderwell headers that will hopefully allow me to lower the front of the car some and not rub the tires. Going to freshen up the engine and trans as it's been a handful of years since that's been done. I have all the parts on hand, so may wait until early 2023 and see what my track is going to offer class wise to determine what kind of ET I want to achieve. I'm thinking of doing a cam swap and possibly lowering the compression some to be in a safer range to run pump gas. Other than that just give the car a good inspection and should be go in the spring.
