Some updates rebuilding the 485" for Dizuster. This is your chance to inform Scott that the engine needs to remain BLACK as he wants it painted OEM bluegreen. Firecore wires (thanks Rick!) are on the way but, here's a pic laying out the wire routing. I have some fittings coming in today that finish the oil system. A wondering eye might catch the oil filter adapter shares a bolt with the air-pump mount which is mounted on the back side of the motorplate. The filter is easily accessible dropping down in the factory K-frame opening. I also choose to Tee the pressure out side to feed the rear of the block fitting that i opened to 1/4NPT.
