One thing to be concerned about seeing you are on the Coast is the type of cooling the engine had , fresh water or raw water . If raw water , and this was an ocean vessel , the salt water can eventually do a number on the cylinder walls from the cooling side . If it had a closed /fresh water system with a heat exchanger that is obviously lessened .
running up my post count some more .
