Originally Posted by BleedDodge
Originally Posted by racerx
I'm liking the hub update option work so your saying the 2000–2001-year hubs will interchange with no issues?......Thank you wave
I’ve never done it, but I know guys who did it, and as I understand the newer ones are a hub with a bearing inside, unlike the spindle on the older trucks with the bearing you can change by itself, the newer ones are self contained apparently. If I were you I would just order hubs for a 2001 and put them on there.
Another thing I remembered just now as I type this is some of the wheels are different too. From 2002-2005 you could only get the flower petal style wheels but some were chrome clad and some were actual aluminum wheels. I had a set of each, and the aluminum ones had less clearance and needed a thick spacer, whereas the chrome clad ones had more clearance and could get by with a thinner spacer. Those chrome clad ones are the ones I had machined and still have on the truck. The aluminum ones I let go of years ago. They didn’t shine as much as they were like a semi wheel with the durabrite coating on them. The chrome clad wheels were prettier IMO.
Thanks for the reply......I Seach Rockauto to see if there 2000 hubs interchange with 1995's with no luck. I'm going to research deeper, iagree the chromes look's much better than the plastic looking gray ones.
