Originally Posted by racerx
Originally Posted by moparx
why won't the wheels fit on the front ?
beer
They do have the same bolt pattern as the rear, but it seems the wheel's bearing cover won't fit the wheel due to the wheel bearing (Hub) cap protrude pass the surface of the wheel. Stopping the wheel cap from seating.
Post some pictures of your truck and the wheels you are trying to put on. The wheels should fit without the center caps.
