Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner.
So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched?
Ron
Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood.
Jim that's why they cut the neck to make a 383 baseplate more like a 440 baseplate.
Ron
This is cut far more than the difference between stock 383 and 440 base plates. I borrowed a 440 base plate many years ago to see if it would work with the 440 in my old Dart. With no gaskets on a core engine the lid hit the hood so I gave up looking for the rarer and more expensive 440 single four barrel air cleaner.
