Very nice!!! Can you share some pictures or advice about how much cutting was involved on your baseplate??
I plan on using a reproduction so I won't feel bad cutting and in actuality would also be cheaper to just go that route. I do wonder if anything would have to be modified on the underhood ducting though? I'd be using this set up with A/C... but a right side upper hose radiator Thanks Ron
