"Now spray paint the converter and flex plate by one of the bolts so it’s easy to line up next time. I do this on the floor before installation." i do this before i separate the transmission if i'm going to use the same combo, and it hasn't been marked like this previously. makes life SO much easier !
X3 I'll also do so with the flex plate if it's off or use another/ spare before install
