Have an engineer come out and assess what you have going on.
In my mind you're going to have to construct a concrete retention wall to prevent it from sliding further.
it's pretty much level ground but uphill. the slabs are slipping sideways on the level plane.
I just had a concrete/ caulk guy here than say water is getting under it form seepage at the joints that are all caulked but some are likely seeping. h quote 5K to re-caulk the entire driveway with an 8 year warranty on the caulk not separating from the concrete.
Hmm I'll be getting up there by that time. Might also try to see if i can get ahold of the original contractor to see if he can offer anything. Strange problem
![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
I do want to thank all that have responded so far
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
