Here are the ARP instructions for their 7/16 flywheel bolts, they do have the undercut head. The other pic is stock flexplate and torque converter bolts...makes me wonder if the differing style is why you get a loose cracked thru the bolt holes plate every once in a while. Reading how the bolts work makes me think stock flexplates are one shot only to be safe.
