Funny this post would pop up. I learned the hard way this year with the new motor. I cracked my convertor and messed up the hub. The cause ended up being that the bolts on the 8 bolt crank were riding against the convertor just slightly, but enough to cause runout. So... there are now .060 flat ground washers between the flex plate and convertor. Haven't made it back out yet.
