I would find the minimum CSA and work backwards from there using PIPEMAX to find cubic inch. Probably have to turn it 9k plus in the lights but most of the All Motor engines are junior Pro Stocks anyway. How is minimum weight calculated in the class?
10Exactly. 2)Exactly. 3)Well, there are the rules and like anywhere else I'd guess there is a matter on how they are interpreted. My INDY S/R 485" with 2 4bbl would be about 2830lbs. Weight breaks for Mopar=-125lbs Teir2 Body=-50 Then a penalty for 2 carbs 10% of CID again about 2830lbs total with driver of course. (EDIT: 480CID is 2940 base weight)
