Very happy with our's and agree with the above. We changed to a beadlock wheel as it's not advisable to screw the bead on a radial tyre. We just used to fit them dry without glue etc, the tyre would move 270 degrees in the rim after about 15 passes. They are heavier than there non beadlock counterpart but you can change tyres real easy, once you get the technique down .
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
