Originally Posted by 8urvette
I went to start it for the first time last weekend.
And my starter failed. Ordered a new one from summit, bought a xspower starter, and it wont clear my headers.
I pulled my stock one apart and fixed a broke solder. and now it works again. SOrta.
Cranked th car a few times and naturally the distributor was 180 off. Not sure how I always seem to do this, but i am very consistant with it. Flipped it around 180* and cranked it over, it coughed and sputtered. cranked it again and it fired up and sorta idled. I have no coolant in it so I turned it off, checked over a bunch of stuff and went to start it again.... started failed. UGH!!!!!!!
I'm running the same set up still have a issue on start up(has a 3 second crank time) I need to check my wiring
but I heard of this issue before... other than that it starts all the time... this is on my Rampage
wave
