The Mazeire flex plate is suppose to be a billet piece. It is .100" thicker. The flex plate in picture is of the Mazeire flex plate. It was taken with my phone. Don't know why it turned sideways when pic was posted. Pic also lost clarity. Mazeire flex plate has a lot more material from the flex plate bolt hole to the outer edge. That is where the Mopar Performance and B&M flex plates use to crack.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
