Originally Posted by lancer493
My true concern here is whether the .059" clearance between the bolt heads and the back of the block is sufficient. Everything is new . Converter, flexplate,and block. All straight and undamaged. Just wasn't sure about flexplate distortion at speed. Anyone had to check this measurement? Thanks, Bill
I don't believe there is any way for it to go forward into the engine with that much room.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
