You can see that the inner sleeve on the new bushing is longer then the rubber. When you tighten the bolt, you are left with a gap between the hanger and the bushing rubber. The inner sleeve is held tight though. On the original bushing, the rubber touches the hanger and is compressed when the bolt is tightened. I'm not sure that this is an issue. Just wanted to hear from others.
