I've got a set of the 0 arch MP oval track springs. The inner bushing sleeve sticks out past the rubber on both sides slightly. When the spring eye bolt is tightened, the inner sleeve is locked in place but the rubber isn't compressed at all. This isn't how the stock springs/bushings were. With the stock springs, the inner sleeve must be a little shorter then the rubber because when you tighten the bolt down, the rubber toughes the sides of the hanger and gets compressed.
Is this an issue? Should I machine down the inner sleeves so they are at least the same width as the rubber or slightly shorter?
Edit: Inner bushing sleeve length 3.110"
Out to out of rubber bushing 3.035"
