Pretty sure Summit has bought out firecore and you can get this crap from them.
Not true ---- Summit and Jegs also carry them and it's just a part any supplier can buy and sell. The problem I had with both of mine was the internal part that held the weights were made of plastic and wore out quickly. It would then jump timing and make the engine run horrible and could have even caused internal engine damage. My understanding is Summit and Jegs had enough buying power that they forced the supplier to fix the issue. Just more Chinese junk anyway!
