Originally Posted by NITROUSN
Quote
It's possible the intake manifold is over tightened. If I hadn't seen it myself I wouldn't believe it but sometimes if you just back off the bolts on front of manifold and snug them back up it can stop a leak. Water leakage is more common at that location from overtightening
No coolant in B,RB, or HEMI intakes.
Correct. The intake is a wedge friction fit and can be overtightened enough to put enough pressure on the head to cause a leak from the main coolant passage in front head gasket. There was a post here a few years ago with several hemi owners that had a small coolant leak at front of head and solved it just by backing off the front intake bolts.
