Do you think a Braille charger would work on a Go Lithium 16 volt battery?
I have 2 chargers and need another 16 volt Lithium battery. You can't go wrong with Go Lithiums price and the new generation battery with the bigger lugs looks enticing
I dont know if that would work. Call Go Lithium they are pretty good to talk to , and answered a lot of my questions
I called and someone on tech didn't really know so he asked another guy and they said it won't work. Braille battery charging rate is higher than the Go Lithium.
Not sure if they are just trying to cover their butts and just want to seel the separate charger.
I would like to try one again at that price but I had no luck with the 1st run of them when they 1st came out.
