I have two questions on the lithium batteries. 1. Are you running the 12v or the 16v? 2. If you run the 16v, do you use any kind of step down device for the rest of your electrical components?
Yes 16 volt step-down on my accumulator green solenoid valve and step-down on my Racepak O2 AF/4 Controllers. If you dont, you will fry the controllers and solenoid almost immediately.
