So I have learned some really cool stuff over the last couple of weeks. I wanted to share with all of you because it can save you a ton of money on your project. I have been buying my parts from this Mopar shop:
https://www.eastcoastmoparts.com/Now for the good stuff. We all swap valve springs. They can be very pricey. 1511's- $489.95, Comp Cams- $365. Okay these are LS parts that work with our motors. Now Mopar has Springs also. Mopar (P5160074) set of 16- $215.60. If you go this route, 68277306AA $4.29 each. Same spring from the kit.
LIFTERS- I have seen them for as much as $1000.00. There is no such thing as a "Hellcat Lifter". The non MDS lifter is what they use. Mopar part # 5038784AD. The set of 4 with yoke is $95.90.
OIL PUMP- Everyone says use the Mopar pump. I grew up on Melling and that is what I bought. Part #10342 $166.00. Mopar Oil Pump #5037687AB $265.68.
Anyway just trying to help those on a budget like me.
