So OP, which cam did you pick??
Lunati Voodoo:
https://www.lunatipower.com/voodoo-retro-fit-hydraulic-roller-cam-chrysler-361-440-270-278.htmlOld cam Comp XE268H
Advertised Intake Duration: 268
Advertised Exhaust Duration: 280
Intake Duration at .050 Inch Lift: 224
Exhaust Duration at .050 Inch Lift: 230
Intake Valve Lift: 0.477
Exhaust Valve Lift: 0.48
Lobe Separation: 110
Intake Centerline 106
New Cam Lunati 20230711
Advertised Intake Duration: 270
Advertised Exhaust Duration: 278
Intake Duration at .050 Inch Lift: 219
Exhaust Duration at .050 Inch Lift: 227
Intake Valve Lift: 0.515
Exhaust Valve Lift: 0.530
Intake Center line: 116
