Friends that work in aircraft have boxes that look like that.
At the end of the day they have to account for every tool.
Absolutely. In the Air Force, if your end product ends up on the flightline, every tool box is shadowed, every tool has its specific inventory number, every box has an inventory sheet, and every box is inventoried
before and after every job. If you're a back shop, at the beginning and end of every shift. Jet engines are like very expensive vacuum cleaners. Sucked up random objects (like misplaced tools) play havoc on them, and they're very expensive to fix. Almost weekly (sometimes more often) an AF flightline gets shut down for a "lost object"...and a "lost object reports" go straight to the maintenance commander (colonel). They're normally lacking in the sense of humor department. I would hope
similarly strict standards are held at civilian airports.
