Originally Posted by Cab_Burge
Originally Posted by csk
And then, WITH the proper spring pressure you can adjust that Hydro roller .020 from the bottom & yes they are still noisy LOL smile
never set the preload so low. NEVER at .020 from bottomed out tsk
All the instructions I've seen show from .020 tp .050 preload max, not .150 + preload twocents
I use from 1/4 to 1/3 turn preload depending if the adjusters are 3/8x24 thread with 1/3 turn or 1/4 turn with 7/16x20 threads with a 1/4 turn HOT up especially with aluminum heads scope
Not going to argue, it works GREAT !!!! smile
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
