I would say it this way......
If you’re expecting the quietness of an oe hyd cam/valvetrain using a retrofit hyd roller cam & lifter combo in an old school platform that includes a typical performance lobe design....... you’re going to be disappointed.
They more often than not will have comparable operational noise to that of a tight lash SFT street oriented profile.
A quick google search for “hydraulic roller lifter noise” will bring you tons of hits for pretty much every engine platform and lifter brand out there.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
