Rubber or rubber type items are considered wear items and aren't covered by any warranty beyond the typical 12/12. Examples would be belts, hoses, weatherstrips and suspension bushings so your anger may be misplaced. Good luck with an aftermarket bushing as well as most of them are pretty much garbage.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
