Gunpowder near exhaust manifolds and electrical stuff?
Pretty sure he meant to use the gunpowder in the way it was intended, to eliminate your squirrel problem with extreme prejudice.
22 shorts will work with a minimum of noise. A good pellet rifle will also do the job even quieter.
But you can try this first if you don't like the other way.
Game warden told us to use a mixture of mayonnaise and cayenne pepper to get rid of a ground hog under a porch. Apparently they love the mayo and when the cayenne kicks in they run away and never come back. Worked for us in one day. I bet it probably works just as well on squirrels.
