Originally Posted by polyspheric
Will GV accept drive & direction from both ends?
Can the mounts be reversed front/rear?
Driveshaft length is the same, U joints are?
See where I'm going?
Can it be used as both 7778:1 overdrive (3.55:1 axle becomes 2.76:1 to kill RPM, reduce gas use, NVH cruising) and by swapping input ends as 1.286:1 underdrive (3.55:1 axle becomes 4.56:1)!!
Easier than changing a ham since you lose no fluid or gaskets, need not pull the axles, etc. The GV is partially subsidized by not buying another 9" center section.
There must be a good reason not to do this that I can't see...
Yes they can under or overdrive
68 Barracuda Formula S 340
